jhautz
jhautz's Avatar
08.26.2008, 10:19 AM
I dont have one, but I have heard this before. I think people are putting some sort of rubber boot over the cvd part of the center drive shaft and filling it with grease of some sort to prevent the heat build up. If you look around on line I think there is even a company that is selling a rubber boot designed specifically for this purpose on the 8ight products
to make it...
or break it...
Silent...But Deadly
JeffEmbracedDC
JeffEmbracedDC's Avatar
09.09.2008, 04:51 AM
A boot over the CVD part of the driveshaft? The only thing I can think of that might be similar to what you're explaining would be the GMK CVD Condoms (http://www.amainhobbies.com/product_...ducts_id/13168) which aren't to do anything with heat but keeping the pin captive in the CVD.
It'd say it sounds like the diffs are unloading way too much or there's excess friction in the gears as e-traxxer has mentioned.
Shims can cause too tight of a mesh and cause excess friction and heat. No shims can cause friction of the spider gears on the case causing heat - so both having shims and not having shims could be the source of heat. I'd pull the diffs out, clean out any an all fluid, put it back together without fluid or grease and see if it spins freely without binding.
If your diffs are unloading you should be able to tell by the size of tires relative to the other tires when spinning. If the fronts are way bigger than the rears on throttle then you need thicker fluid in the center diff. If the left wheels are way larger than the right wheels when making a left-hand turn, or vica-versa you'll need thicker fluid in your front or rear diffs (or both). A good starting point for truggies is 7/10/5 meaning 7,000 in front, 10,000 in the center and 7,000 in the rear.]
Also make sure the bearings on the diffs are spinning freely. If they're binding they could definitely cause friction that transfers to the outdrives and diffs.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
