08.26.2008, 08:07 PM
That's a possibility I suppose. I still don't like the whole shunting protection scheme, but that's just me. Leaves too much room for high enough currents to sizzle a wire, which may cause collateral damage depending on how bad it is.
I'm not saying my idea is better per se, but it is more elegant. The best thing would be to have some type of protection built into the BEC itself IMO.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.26.2008, 09:54 PM
The zener wouldn't be a shunt with my method, it would conduct into one terminal of the relay. Once the fuse blew, nothing would be conducting. This doesn't change the fact that some type of protection should be built in. My CC BEC has been working flawlessly. Let's hope it continues to do so.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.26.2008, 10:41 PM
Hey guys... I haven't kept up with this issue. Is it common that the CCBEC lets full voltage pass through if it fails?
Does it seem like there are quite a few going bad?
I was getting concerned a while back when there were a couple reports.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
big greg
08.26.2008, 10:47 PM
yea im running one in my buggy, its been goin a long time now, no issues, now i jynxed myself
asheck
08.26.2008, 10:48 PM
I'm not sure what the failure rate is.It doesn't seem to be highly reported,but 2 out of 2 of mine failed in 2 different vehicles.
azjc
08.26.2008, 10:49 PM
I dont think it happens a lot but if it fails it can fry your Rx and servos......that can be over $200 for a failed $25 componenet...I guess a Rx pack is the only way to be 100% sure it wont happen
coolrunnings
08.27.2008, 12:43 AM
j3110 try ebay bro otherwise you may not even be able to give it away. Ive never had one fail because ive been smart enough not to own one. I only run western robotics hecules bec or dimension engineering bec's they rule.......sorry sammus.
Sammus
Sammus's Avatar
08.27.2008, 01:11 AM
dont be.
j3110: you can give it away to me :P
kona
08.27.2008, 02:17 AM
You can increase the power handling of a zener by adding a power transistor. I think this is what what'snitro was saying except with a transistor. The transistor should be able to dissipate the power, but if you are afraid of melting wires, you could add a fuse. The nice thing about the zener shunt is that it is completely passive until needed.
TruckBasher
TruckBasher's Avatar
08.27.2008, 02:26 AM
its been a while since I saw a schematic....
Watching this thread......i dont want to waste an expensive RX/Servo
E-Slayer direct drive to diff
glassdoctor
TEAM FUSION
08.27.2008, 06:20 AM
Hmmm...
I'm going to feel kinda guilty if any of my buddies has one take a dump and they lose $200 worth of rx/servo.
"Friends Don't Let Friends Use a CCBEC"
LOL!!!
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Semi Pro
Semi Pro's Avatar
08.27.2008, 09:07 AM
wow this post scares me, i thought that the 3 ccbec's i bought were helping keep my stuff safe not putting it at risk.
since i race and weight is very important whould i remove them all?
if a ccbec smokes my stuff what is castle going to do about it?
08.27.2008, 09:55 AM
Yup, that should work. Once the output voltage exceeds the zener voltage, there will be enough current flow through the resistor to bias the transistor, which will dump the voltage to ground, which will then blow the fuse.
What's_nitro?
08.27.2008, 01:23 PM
Yeah that was what I meant. Sorry, I was too lazy to draw up a schematic, upload it to photobucket, and post it here. One small difference is that I would put the circuit across the power leads, but have it triggered from the output. Although you see full voltage either way, attaching it straight across the batteries (input) instead of the output of the BEC would allow for faster current rise and the fuse would blow sooner...
J3110
08.27.2008, 04:01 PM
Originally Posted by Sammus View Post
dont be.
I'm gonna hang onto it for a little while as a backup, but you definitely have dibs. :)
