Home grown One Way Shaft
Dafni
Dafni's Avatar
Home grown One Way Shaft - 10.24.2005, 07:28 AM
Lads, this is an easy to make hopup. I came up with it when I made some center shafts for my BL Revo. Got inspired by the Quickturn thingy.
Here's what you need:
-Maxx slider shafts (f/r)
-Maxx yokes
-Maxx stub axle
-6mm one way bearing
And here is what it looks like on the inside:
The build up is pretty self explaining. I modified the female slider on a lathe. Took the outer diameter of the OWM minus 0.5mm as an inner diameter for the shaft.
The OWB got pressed into the shaft on the lathe, and it fits very well.
You can do this without a lathe, just use a 9.5mm drill bit and a vice to press the bearing in.
The OWB, in my case, sits nice and strong in the shaft. I was worried about it turning in the shaft, but so far it worked very well.
Keep in mind, it's only useing Maxx shafts and yokes, so it's not bullet-proof. It's good enough for some experiments, but if you like it, I would suggest the Quickturn.
A front OWB requires a completly different driving style, and I only use this goodie for experiments. You loose front brakes (not necessairily a bad thing, but I like 4 wheel braking better) but you gain off-power steering.
My vote still goes to a center diff, though.
DAF
squeeforever
squeeforever's Avatar
10.24.2005, 08:17 AM
thanks daf!
crazyjr
crazyjr's Avatar
10.24.2005, 09:17 AM
Drive it like you would a stadium truck, tap brakes to get it to slide then punch it when it's pointed in the direction you want.
Dafni
Dafni's Avatar
10.24.2005, 09:45 AM
Yeah, I know. I'm rather good at it. Can spent hole packs at my tight wood track without ever hitting one tree :D Pure adrenaline.
Come to think of it, Crazy, that's how I drive all my trucks. But with the OWB, it slides its back out, instead of the whole truck. Kinda hard to explain, but I guess you know what I mean.
Cheers
DAF
coolhandcountry
coolhandcountry's Avatar
10.24.2005, 10:12 AM
Is that it. I thought it was going to be hard to do. Thanks daf. I may try me one for my stocker. See how it does. I like the way it turns in two wheel drive better.
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
10.24.2005, 11:03 AM
Yeah, that's it. Told you it's simple, almost not even worth posting. A rather obvious thing to try.
starscream
RC-Monster TQ
starscream's Avatar
10.24.2005, 12:51 PM
Nice DAF,
I always wondered what this looked like.
I would recomend trying both a center diff and a OWB. That way you could get the benefits of both. Just a thought anyway.
Although for me, it would require me to use an emaxx style tranny instead of the automatic two speed. NOt necessarily a bad thing, I just really like the automatic shifting.
:cool:
Cheers
Ha Ha
Dafni
Dafni's Avatar
10.24.2005, 01:25 PM
Cheers! :cool:
I think when I get a solid centerdiff, with steelbones to the f/r diffs, I'll stay away from flimsy owb makeshifties. (nice word, does it makes sense at all? :L: )
coolhandcountry
10.24.2005, 01:48 PM
a center diff with a owb. That sounds like 40mph with no brakes. Have to run some thick oil. I don't think I will try that. Could be hard on the front end. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
crazyjr
crazyjr's Avatar
10.24.2005, 05:16 PM
Cheers
DAF
When i raced my Emaxx that's how i drove. If i had a owb in the front i could turn tighter. I could already turn on a dime, maybe i could get change with that one-way.
Serum
Serum's Avatar
10.24.2005, 05:24 PM
Cool Dafni, you did take my hint for serious.. ?
Dafni
Dafni's Avatar
10.25.2005, 01:05 AM
Squee was asking for it.
rchippie
rchippie's Avatar
10.25.2005, 01:14 AM
Daf you said you modified the female slider on a lathe. Do you took the grooves out of the slider then pressed in the bearing ?. Also is that a wheel axle with the threads cut off ?. Thank's
REAL MEN RUN BRUSHLESS
Dafni
Dafni's Avatar
10.25.2005, 01:21 AM
Yeah, it's a stub axle. Cut at the hole.
And you're right about removing those grooves. I had a 10mm OWB, so I lathe'd the slider out to 9.5mm.
DAF
rchippie
rchippie's Avatar
10.25.2005, 01:30 AM
Did you cut the axle behid the hole closer to the yoke ?. What kind of abuse can it take ?. Can it handle racing a 9L on 14 cells week in & week out ?.
Mike is shipping my modifed diff out tommorow. So my buggy will be kicking some nitro butt this weekend:eek: .
