09.02.2008, 10:23 AM
BrianG, on this pics, i can see the removed parts, the bridge on the switch wires, but were is the brown wire goes on the Rx????
And after the mod, i know you run an external BEC but did you remove the red wire in the Rx plug?????
Do you have to route the external BEC output wire to power the ESC????
Please i need clear expanation, and tell me if i can do this on the V2.
I'am french and sometimes i've somes difficulties with english explanations.
Thank you
I removed the ground wire on the throttle because the input power ground is the same point as the throttle ground, so that means fewer wires. If you look at the wiring diagram, you can see I'm picking up full battery power directly from the ESC power solder points.
