BashemSmashem
09.02.2008, 11:08 AM
I don't think you should have too do ANYTHING too the MMM too get it working correctly .
It should work the way its advertised too do and thats it , end of story .
kulangflow
Never Fast Enough
kulangflow's Avatar
09.02.2008, 12:34 PM
Nobody disagrees with you. It should work properly, so you shouldn't have to mod it.
The reality of the situation is that many of us want to band-aid these things until Castle figures out the real solution. The only alternatives are to not run our vehicles, or to spend money on different products, most of which will also need band-aids of some form or another.
If my next one fails, I will choose to mod it so that I can run my truck until Castle resolves the real fix. A slightly modded MMM is still better than anything else I've used, IMO.
J3110
09.02.2008, 02:06 PM
Clearly, if you want a product you can rely on, don't get the MMM, I get it.
I had 2 backups, so I was not one of those people. Sure, it is frustrating knowing a product you bought is most likely going to fail.
Have any modded MMMs failed yet?
