bdebde
That's All Folks!
bdebde's Avatar
09.03.2008, 07:03 PM
I don't use RCM mount (made my own) but the finned can fits with even the smallest pinions (10t), The rcm mount should do the same.
You will certainly need a 1521, I would steer clear of the 1D though (amp hog), The 1.5D or 1Y (my preference) would be better IMO. I think satttheman was getting about 60mph with the 1Y.
I too would be unsure the MMM would be the controller to use, still running the cr@p out of mine to see if it holds up. I really like my MGM, still trying to see if the MMM is enough to replace it. MGM has some new models coming out with some more features and 250 - 280 amp power handling.
If going for speed, I would certainly go for the evo 30 batts.
Innovative_RC chassis is one stout chassis, I love mine.
Haven't had any need for the rpm arms; still have not broken a stock one yet.
The Muggy has 20mm hexes which are fine, but limit you to losi wheels. I also have the 23mm adapters for 40 series wheels/tires. Not too sure how the 40 series road rages are; I never liked the 2.2 or buggy size as they balooned like crazy. I also use 17mm hexes for HPI phaltline wheels/tires, and they work without any problems/stripping. You may want to go with the phaltlines if just running mainly on road, but do not get the pre-glued ones (HPI does cr@p glue job).
OH, and welcome to the forums!
