Joram
Nitro?? BL rulezzz
08.11.2008, 11:17 AM
I thought the Zippy weren't good??? I'm going to run op NEY 1515 2.5d... so i need enough power...
Greetz,
Joram
  Send a message via MSN to Joram
plaviblue
plaviblue's Avatar
08.31.2008, 10:44 PM
Have you had any trouble with over heating?
saydee1800
09.07.2008, 03:16 PM
do you run reverse
are you still using the manual brake
BADBOY2
09.07.2008, 09:48 PM
Originally Posted by killjoyken View Post
I've made a few updates to my Savage.
XL super Heavy duty axles
Tekno Neu 1515/1Y
6s Trakpower (3packs in series)
Aftershock shocks w/aluminum caps
XL 52t spur gear
I haven't run it yet, but should get a chance this weekend.
Pics:
Something's gonna break for sure!
where can i buy these straps?rc monster have them?
saydee1800
09.07.2008, 10:04 PM
do you have reverse in the truck if so what kind what brake are you using
killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
09.08.2008, 02:07 PM
I got the 12" straps from Fry's Electronics. I use 8" straps for my 4s lipos.
I don't have reverse and I'm using the stock dual disk brakes. There should be pics of my brake setup on the first page. I haven't had a single problem with the brakes.
Fast5sRevo88
09.08.2008, 03:14 PM
Are u still running the 3-speed with it on 6s?
killjoyken
killjoyken's Avatar
09.09.2008, 02:16 PM
I was running it on 4s for a while since I had to go back to a MM while my MMMs were back at Castle. Then I did a complete tear down and rebuild, cleaned everything, and replaced some tweaked parts. BTW, the 3-speed is still perfect.
I'll post some new pics when I get everything back together.
saydee1800
09.09.2008, 09:44 PM
have you ever try the xl savage extended aluminum axles
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.09.2008, 10:31 PM
Have you got those packs Velcroed together so the cant slide forward and damage the plugs?
Fast5sRevo88
09.10.2008, 06:44 PM
Yes, Ken has the batts velcroed together, in one of the previous pics, u can just barely see it, it also says it somewhere near the pic.
killjoyken
killjoyken's Avatar
09.22.2008, 08:58 PM
Finally put my Savage back together last week with a few changes. This one is built for top speed/drag racing and I'm building a 2nd FLM Savage for bashing. This one's got HPI Phaltlines, HPI big bores, and a Tekno Neu 1515/1.5d powered by a MMM V2 w/CCBEC. I ran it on 4s to tune the suspension and it was doing pretty well.....until I lost control at about 50+ mph and slid sideways into a curb. Amazingly I only put a small crack on the inside of the rear wheel and bent the crap out of a rear CVD.
Pics:
Monster Max mount for quick fan replacement as well as keeping the case from popping apart. It also doubles as a flame guard for my lipos!
plaviblue
plaviblue's Avatar
09.22.2008, 09:31 PM
I notice the external bec with the MMM. I did not think you needed one. What does ccbec stand for?
killjoyken
killjoyken's Avatar
09.22.2008, 11:18 PM
Technically you aren't supposed to need a bec with the Monster, but since there have been problems with the internal bec failing, this is a preventative mod. CCBEC stands for Castle Creations BEC.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.22.2008, 11:39 PM
The CCBec is keeping my MMM alive I'm sure.
Why do you have the big spacer under your motor?
That looks awesome. Love the body. I'm waiting on a radar gun to arrive so I can clock mine. I didn't build it for speed but it flies.
