09.12.2008, 11:21 AM
I like axial and maximizer beadlocks way more than pro-line. My pro-lines constantly lost the bead. I still have occasional bead pop outs with the first two, and no longer use the pro-lines. Taping the tires helps a lot too, if the tires pizza cutter they tend to pull out of the bead, but taped it's a lot less of a problem. I always wear out my tires, so cost wise, it's better for me to glue tires. If the tire is shot, cut it off and reuse the wheel, which is a fraction of the cost of beadlocks, and if you've worn out 2 or more sets of rubber your wheels are probably hashed beadlock or not. So, in conclusion, I like the beadlocks, don't like the cost, but you just can't beat the cool factor....... "Yeah, those are real beadlocks!" p.s. I don't threadlock 'em, no probs
