Raze ST Truggy
09.14.2008, 07:15 AM
I've reead the reviews on the HC chargers, and so I use a multimeter to check the individual cells regularly also. Here is the charger that I have:
http://www.hobbycity.com/hobbycity/s...idProduct=5606
and it's specs:
Spec.
Operating voltage range: 10.0~18.0Volt
Circuit power: max. 150W
Charge current range: 0.1~7.0A
Discharge current range: 0.1~5.0A
Current drain for balancing Li-Po: 300mAh/cell
NiCd/NiMH battery cell count: 1~27 cells
Lithium bettery cell count: 1~8 Series
Pb battery voltage: 2 to 36V
Weight: 574g
Dimensions: 170X110X35mm
Can it not even put out the 150W that it is rated for? I should also note that when ballance charging the pack the charger would always charge the cells to 4.25v each. I do like the hyperion chargers, so maybe I'll look into one of those at some point.
-Brian
tc3_racer_001
tc3_racer_001's Avatar
09.14.2008, 04:32 PM
personally, ive gone for an expensive high (er) quality charger and saved money on the lipos. the charger will last a lifetime (hopefully) but expensive lipos could only last as long as 10 cycles if it over charges them and inaccurately balances them.
why not in the future just stop the charger a bit early. you will only lose a few mah and it will increase the lifespan of the pack by a long shot. i was going to get the 106 from there but they arent stocking it any more!! (similar specs to the hyperions, with discharge and super accurate balancing + pc logging for $90 less than i spent. anyway, good luck!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
