MetalMan
MetalMan's Avatar
09.18.2008, 10:26 PM
Okay, with brake and throttle EPA set to 100% on channel 2 and the trim all the way negative, the HV-110 armed right away. The amount of trigger throw before power is applied to the motor is perfect, and I can actually set this using the sub-trim.
This means I have two PiStix adapters and no real need for them...
