So I have begun designing and constructing a center diff for the erevo / new emaxx tranny. Basing my design around a std 1/8 scale diff cup. So it will employ 4 spider gears and 2 output gears. My current diff cup is a HPI al savage cup that has the steel blocks to reinforce the cross shafts. Strongest design I could find. My adapter will also fit any kyosho, OFNA, or hot bodies cup, and any other cup that has the std 4 hole mount pattern.
Some pics:
The al adapter is not complete yet. It still needs to be cut to the correct length and the end tuned down to accept a 8x12 bearing. The black gear also needs to be milled to a certain thickness, as you can see in the 3rd pic it sits too high compared to the input gear. I have done the measurements and should be able to have the machinist finish the adapter on Monday.
Due to the overall thickness of the diff cup and the adapter, and the diameter of both they will contact the idler gear. My only method of fixing this issue is to remove about 1/5 of the thickness of the teeth from the idler for adequate clearance.
This is necessary due to the mounting issues with the stock lower gear to the adapter. If I can have a gear custom made, I can modify the adapter to place the gear closer to the face of the diff cup, although I may never be able to get it close enough to work without some trimming of the idler. Just not enough room inside the stock tranny case.
More info when I get some more progress! All ideas and thoughts welcome...
