MetalMan
MetalMan's Avatar
09.21.2008, 12:12 AM
There's one simple law that explains it all: Ohm's Law, which states that V=IR (voltage = current x resistance). If you don't change the gearing, then R (resistance) remains the same. So by Ohm's Law, current will increase proportionally with voltage. This doesn't always hold true, however, because you could change your driving style.
