tc3_racer_001
tc3_racer_001's Avatar
09.21.2008, 07:48 PM
yes that makes sense. theres no point in balancing when they are less than 75% full. the cells will usually sort themselves out near the end, but i just plug them in and let the charger do its own thing :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
myndseye
myndseye's Avatar
09.22.2008, 02:25 AM
<> as long as you don't have your voltage so high that you are revving into your motors inefficiency rpm range, the following statement is almost always true. In a truck with two available setups, if it's geared to go the same speed with each setup, the higher voltage setup will draw less current.
jhautz
jhautz's Avatar
09.22.2008, 09:16 AM
Originally Posted by azjc View Post
another option is to run a motor with a lower kv value
+1. Lower kv motor, plus that higher voltage and the same gearing will yield the same result, better even perhaps
I agree fully with the lower kv motor option. A much better solution than just gearing down a motor spinning way faster than it needs too. No need to spin the motor much more than 30K rpm in my opinion.
Adding voltage and just gearing down to attain the same top speed can help a little if you are having ESC temp problems, but really wont do anything for you as far a motor temp problems in my experience. It may actually cause motor temp problems from what I have seen.
Getting a motor of the proper kv range for the voltage you plan to run is by far the best solution.
Higher voltage, lower motor kv, and similar gearing will product the best results for lowering current (amp) draw.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
09.22.2008, 09:31 AM
HV rules .
