shizzon
shizzon's Avatar
09.22.2008, 07:06 PM
truck is equipped with Spektrum Radio, vxl system, hitek HS 645 MG servo with aluminum servo arm, fast lane machine rear shock tower and caster blocks, rpm from shot tower, proline dirtworks rear tires, traxxas big bores front and rear, traxxas aluminum steering belcranks. and running 32 pitch pinion/spur with 11 tooth pinion and 54 tooth spur. would like to gear up a bit, but the 11 tooth is all my LHS had, truck is still a blast and is much more drivable with this setup than that 23/86 48 pitch that i used to run.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
