Dafni
Dafni's Avatar
10.31.2005, 06:17 PM
Yes, you can shorten the blue wires, no problem. But leave the motor wires as they are.
squeeforever
squeeforever's Avatar
10.31.2005, 06:22 PM
Originally posted by Nick
Does the 9920 have 6 wires like that? Where they need to be paired for the motor? If so I need more connectors! Might just direct solder them...
yes, the 9920 has 6 blue wires. all you do is solder the pair into one connector. so all your gonna need is 3 male and 3 female.
toby
toby's Avatar
10.31.2005, 06:24 PM
i was just going to direct solder two wires to one motor lead. and then the next two to another etc.
rc18mt/blade cp
squeeforever
10.31.2005, 06:38 PM
i would suggest using connectors.
toby
toby's Avatar
10.31.2005, 06:52 PM
like deans? and if so how do you solder one dean to one wire?
rc18mt/blade cp
squeeforever
10.31.2005, 06:56 PM
no, i would use 3.5mm connectors. http://www.rc-monster.com/products.php?cat=21&pg=2
i would use deans on the batteries.
toby
toby's Avatar
10.31.2005, 06:58 PM
i have NO time to order it, so i guess direct solder is my only choice
rc18mt/blade cp
Nick
COOKIES!
Nick's Avatar
10.31.2005, 07:12 PM
Same here, I have bullet connectors but I don't think I can fit 2 wires in one, unless I solder one wire further down the other? Best to direct solder?
~ Nick.
toby
toby's Avatar
10.31.2005, 07:14 PM
Mike told me to direct solder
rc18mt/blade cp
squeeforever
10.31.2005, 07:51 PM
actually the dual wires fit quite easily. i didnt have any trouble.
mothman
11.01.2005, 02:25 AM
Toby where did you get the 12020? are they warrior or micro??
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.01.2005, 07:13 AM
Mike sells them here of course!
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
mothman
11.01.2005, 07:44 AM
Can you let Toby answer the questions? I just want to know whether he got the Warrior 12020 from Mike or from somewhere else.
toby
toby's Avatar
11.01.2005, 08:25 AM
i got it from here and it is warrior
rc18mt/blade cp
mothman
11.01.2005, 09:03 PM
I thought they are out of stock..I want the warrior tooo... :( Mike, when are they going to be available again??
