tc3_racer_001
tc3_racer_001's Avatar
09.23.2008, 11:56 PM
thus voiding the warranty. ill just leave it be, and if it fails -its castles fault!!! but with them touching (look down the bottom, its almost glued to the heatsink...?)
u could always just cut the fin/s off?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
09.24.2008, 12:09 AM
Well yeah, but I didn't realize the warranty was a factor. And I think cutting the fins would void it as well.
tc3_racer_001
09.24.2008, 12:30 AM
not as bad
but until castle figures out everything eslse and we see the new case design these are here to stay imo.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.24.2008, 01:34 AM
Would heat shrink work?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
joeling
joeling's Avatar
09.24.2008, 02:28 AM
After this potential problem was pointed out in this forum, that's what i did. However, some of the posts were so close to the heatsink that I had difficulty to insert the shrink. In addition, the shrink also interfered with the case. Had a difficult time putting back the case.
I'll try to put up a pic later for more clarity.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
Novak Glitch Buster Capacitor
Maciolus
Novak Glitch Buster Capacitor - 09.26.2008, 03:54 AM
Do you think Novak Glitch Buster Capacitor will reduce possibility of failure?
It is supposed to "store power from the Battery Eliminator Circuitry (BEC) and act as a filter to eliminate noises generated by servos" and "reduce load on BEC".
Do you know parameters of that capacitor?
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
09.26.2008, 09:50 AM
Depends on what is causing the failure. If it's simply amperage load, then no, it won't help. If it has something to do with filtering, then maybe. If the issue is with a bad BEC component, then no.
A cap inherently stores a charge and filters out AC. So, it provides a "reservior" of sorts that will help with current draw when servos need more peak currents. However, if the load requires a constant high current, a cap won't help much at all. It also helps get rid of noise that may be present on the BEC output. However, if the noise is getting in elsewhere (antenna, throttle/steering signal line, etc), it will not help.
Don't know the parameters of that cap, but $13 plus whatever the shipping costs are is a bit overpriced IMO. Just go to RadioShack and pick up a 1000uF (or higher) 10v (or higher) capacitor and solder a servo lead to it.
jhautz
jhautz's Avatar
09.26.2008, 09:59 AM
Here is another option. Marketed for a different reason, but essentially the same thing. A capacitor on a rx plug. less than $5 too.
http://www.amainhobbies.com/product_...oducts_id/6570
to make it...
or break it...
Silent...But Deadly
Maciolus
09.26.2008, 10:14 AM
I have just bought 6,3V 1000uF cap. Unfortunately not SLR.
I hope that simple (13 cents value) mod will lower possibilty of failure. Keep your fingers crossed tomorrow :)
Base of heat sink in my MMM V2 is touching battery connectors :/ I hope little silicone will prewent short-circuit.
Maciolus
09.28.2008, 01:22 AM
I hope I am in happy 50% of MMM owners ;) It works, with some mods, after at least an hour racing. Peak power with Medusa 60-1600 on 6S A123 was 1807W :)
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
09.30.2008, 02:23 AM
well, after my case mods and adding shrink around the bullets, as well as using a UBEC...it didnt matter.
My 2nd MMM v2 took a dump. :(
I'm gonna roll the dice on a MM with a BEC and a fan.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
DRIFT_BUGGY
09.30.2008, 03:55 AM
Unlucky, haven't heard of to many going up in smoke using a ext. bec
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
George16
Supermaxx
George16's Avatar
09.30.2008, 06:01 AM
I think your's is the first to take a dump using a UBEC.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
RBMike
RBMike's Avatar
09.30.2008, 10:57 AM
No he's not
hoovhartid
hoovhartid's Avatar
09.30.2008, 01:52 PM
It didnt smoke actually.
It just stopped. It was running, then it wasnt. I thought I was seconds away from seing casper so I stopped pulling the trigger.
I took the lid off the truck and she was just sitting there.
Checked all my wires and connections, plugged in the castle-link and nothing. she was completely dead.
