Gee
A Horse's Ass
Gee's Avatar
10.05.2008, 01:26 PM
Holy crap is this for real?
http://www.amainhobbies.com/product_...ducts_id/23510
Typed in differntial fluid and these were on there. Anyone spend that kind of money on a differential?
Seem to be in the hijack mood but it's related to the differential fluid question. Can't remember where i read it. It was recommended that a lighter fluid (not "lighter fluid", lower viscosity?) be used in the smaller 1/10 - 1/12th truggies vs the 1/8th scale. Is it going to hurt the performance of a smaller truggies to use the same f/c/b fluid that is used in a 1/8th scale? All I have is the three pack (10, 30, 50K) from traxxas.
I kinda understand the purpose of using the differnt wieght fluids in each differential to improve performace . It seems that if you go too heavy of fluids in all the differentials it would also make the motor work harder. Say instead of using something like 30/50/10k go with the lower viscosity 7/10/3k. Just threw some numbers in there for wieghts. Would the results be the same as the effect on the differential but less work on the system?
Hope my question(s) makes sense to someone.
