Hardstyle
Hardstyle's Avatar
10.07.2008, 04:25 AM
I found the bad solder what caused the gogging, it was so bad that if I just twisted the connector it cutted the power . Now the esc works much better, but still a little glitch at the startup, in my memory it has done always that..
Did a few speed passes at the street, dang it goes smoothly So much power and what a speed. Temps: battery 28°C(82.4°F), esc 38°C(100.4°F) & motor around 50°C(122°F). I think I can still gear up a little and hope that motor will cool down a bit.
Still have to mount all the wirings and now have couple questions about on/off switch and fans.
I have now On/off switch between bec and receiver, started to wonder that can I place the switch after the batterys? So I could close the bec/receiver circuit at once. Can the switch handle over 20V?
And about fans, I have two 35mm 5V 0.7 watts fans, can I plug 'em in to the receivers 3rd channel?
Im gonna do more tests today, if I get the wirings etc. done. So video and elogger graph coming soon.. Stay tuned!
