Well, I would also check the traces on the LVC PCB, chances are they got pretty warm too and might have melted as well. While you're at it, you might want to check out your connections (solder and the connectors themselves) to make sure everything is ok. Won't help much if you fix everything, but don't address the original problem that caused the whole thing...
