Originally Posted by jhautz
Well the 6000 have a slightly higher discharge capability according to the specs and the run time will obviously be longer. all this you know.
Even if you are on the edge of the packs capability, what options are there for better packs? None come to mind at the moment.
All I can do is run a pair of 3700 6s packs in parallel, but that is getting big and heavy, and will most likely not fit my battery area. I could go down to a pair of 3300 6s packs in parallel, but would like something more versatile.
I will try gearing down a bit and see what that does. New 6000 3s packs are 120 each, and I would rather put the money towards a mill/lathe...
