Savage conversion help
virusss
virusss's Avatar
Smile Savage conversion help - 11.06.2005, 02:44 PM
Hallo boys, i have I have as soon as bought a feiago 7xl+20120 micro car+lehner 2800xl, hour I would want to know if this kit allows me to complete the transformation and if it makes me to brake with the motor and not with the servo...,another question for this setup (Lehner2800/feigao 7xl+12 celle) an 15 tooth pinion is ok?My savage is 4.6 ss kit.
Thanks very much for help...
the kit is:
http://www.monsters-paradise-shop.de...products_id=54
squeeforever
squeeforever's Avatar
11.06.2005, 04:36 PM
which one are you gonna run? lehner or feigao? the feigao would probably require a larger pinion than the lehner. if i am not mistaken those kits lock the transmission into 1st gear. somewhere on here there is a post that tells you how to lock it into second with some epoxy which would allow you to eliminate the brake servo.
coolhandcountry
coolhandcountry's Avatar
11.06.2005, 06:54 PM
I don't know alot about savage. The conversion kit come with a single speed which locks it into first gear. I don't know about the size of pinion but the 7xl will take a bigger pinion than the xl 2800.
virusss
virusss's Avatar
11.06.2005, 07:04 PM
thanks for the reply boys,I wanted to know if it by force must block the gear, or if possible to let the automatic gearshift?
squeeforever
11.06.2005, 07:13 PM
i think it locks it into it making no second gear. i would lock it into second with some epoxy.
coolhandcountry
11.06.2005, 07:19 PM
YOu can use the auto shift 2 speed. will need the brake servo hooked up with esc with a y connector. If you want reverse you can do that as well.
squeeforever
11.06.2005, 07:23 PM
it shows you how to lock it into second here so you can use the motor brake. http://www.rc-monster.com/forum/show...5&pagenumber=2
virusss
virusss's Avatar
11.07.2005, 04:39 AM
thanks thousand boys when it arrives to me all, I will make a tests and I will make to know you
virusss
virusss's Avatar
11.07.2005, 05:28 AM
Boys i have seen I little have inasmuch as in many setup the 3200 are used kokam, but not is a little like capacity, inasmuch as the lipo they have currents of discharge of 15/20c (3200x15=48 AMP)non are little for a motor type feigao 7xl?
joeling
joeling's Avatar
11.07.2005, 11:44 AM
Hi,
I have experience with this same kit with the exception that I bought it from the US. As mentioned, it locks the truck in 1st gear. The kit comes with a 18T pinion. If you install the full kit, there is no need to retain the mechanical brake (can't anyway as the battery will interfere with the brake control linkage) as the special shaft replaces the one way device in the gear box.
I have run the truck with the conversion kit installed with a feigao 7XL & BK 9920 esc & it worked fine. The batteries used were Kokam 20C 3200mah 5S lipo.
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
virusss
virusss's Avatar
11.07.2005, 11:50 AM
thanks for reply joeling, but 3200 mha is not too little?
3200x20c=64 amp?I believed at least of the 6000 for these absorptions 90/100 amp, an other thing 5s in total(18.5 volts)? Thanks
joeling
joeling's Avatar
11.07.2005, 12:07 PM
hi,
while I am no expert, i believe 64A contiuous & even higher current during surge is sufficient to make the truck wheelie if the gearing is right. i think the spec says the 7xl can draw more than 90A max. however, that does not mean it needs to draw that much current all the time to function properly. guys, feel free to correct me if i am uttering rubbish.
regards,
joe ling
ps: sorry for the poor punctuation. i am using my touch screen on my audio pc upstairs in my listening room to do the typing
virusss
virusss's Avatar
11.07.2005, 01:32 PM
thanks joeling,dont worry for your punctualing, my english is more bad :)
Serum
Serum's Avatar
11.07.2005, 04:17 PM
Hello Viruss!
That kit from monsters-paradise is to lock it in 1st speed.
it's not too easy to lock it in 2nd, because that gear needs some extra holes to lock.
You could use the 2 speed transmission. just get a heavy duty 2nd speed and you should be fine.
dabid
11.07.2005, 04:23 PM
The diagram that pocono put up doesn't make it look that hard, but that'd put it in 2nd, right? Would it be better to have it locked in 1st or 2nd though?
