hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.21.2008, 05:12 AM
I can not take credit for this pic, only for being smart enough to save it to my computer
I can take credit for the pic! Thats my truck!
The lotus body behind it is for my TC4.
Lookin forward to watchin this linc!
Have you considered using a bigger spur to get the clearence over the shock mount you need?
...Of course, that would mean bigger pinion, etc....
*EDIT*
Maybe run a couple of these with lutechs 10s;
http://www.hobbycity.com/hobbycity/s...Ah_21-35C_4S1P
Similar speed, and you may not need to mess with the shock mount if you get enought clearance with the larger spur.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 24
Total Voltage: 29.6
Motor KV: 1577
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 80
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.25 : 1
Total Ratio: 11.74038 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Total Motor Speed: 45669.92 RPM
Vehicle Speed: 68.28 mph (109.68 km/h)
Estimated Adjusted Speed: 62 mph (99 km/h) - 9% loss
Effective KV Value: 1542.9
KT constant: 0.86 oz-in/A
Motor Torque: 0.36 ft-lbs
Final Torque: 4.2 ft-lbs
Final Power: 2368 watts (3.2 HP)
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
