Thread Tools Rating: Thread Rating: 10 votes, 3.60 average. Display Modes
sikeston34m
sikeston34m's Avatar
10.21.2008, 09:09 PM
I also think the 4 pole mentioned by Patrick will still have more torque being it has twice the magnet. Basically a 2 pole would be a 4 cylinder and a 4 pole would be 6 cylinder and 8 pole well would be 8 cylinder. Ever wonder why outrunners have more torque then our popular 4 pole inrunners?
Did someone say outrunner? LOL
I for one can testify to the torque of the outrunner. In the experimental direct drive setups that I have built, a 12 pole outrunner with a low (600kv to 1000kv) has enough torque to shatter diffs and even bearings. I'm talking acceleration, not shock from jumping. They can also easily pull gearing that 2 pole motors will smoke over.
When considering torque, think about how many rotational degrees each phase shift is required to turn the armature, often times with close to the same amount of magnetic strength as a 2 pole.
Armature Diameter has a huge impact on torque. It's just a matter of leverage or distance from the magnetic force to the rotational center.
Tags
1515 1y, brushless, castle neu, mamba monster, mmm
