stum
10.22.2008, 07:57 PM
Originally Posted by Sammus View Post
Not very well. If you do a 2x2 4s shotgun pack it will nearly fit, but will stick out by a couple mm and youll need some other way of securing them in there (battery doors won't close). Or if you get the extended wheelbase rear arms, you can fit a side by side 6s pack in there which will stick out nearly an inch. (without the long wheelbase rear arms they're too close to the rear tyre).
I can't recall exactly but I think the max battery size is LxHxW = 165mm x 30mm x 51mm
I know the biggest pack I could find to fit in the erevo tray was the maxamps 2s2p 8000mAH lipo (20c version). This held up fine to any/all abuse and really maxed out the space for hight and width, but there was still some length in there. I saw a few photo's and the true-rc packs and SPC 8000mAH 2s lipo's also took up the entire space and were longer to boot (also weighed more than the maxamps)
