Unsullied_Spy
Unsullied_Spy's Avatar
10.24.2008, 05:16 PM
They are the best because they are the most expensive, isn't that how it works?
Neu motors use a very good design and high quality materials. You end up with a more powerful motor that is also more effecient (runs cooler) and is lighter. Plus they are made to better tolerances and should last longer. Generally everything is better, and you pay for it. They are also hand made, which drives the cost up. Plus Steve has to make some money on them!
The MMM/castle neu combo should be the best of both worlds. From what I have heard the castle neu motors work as well as the real neus, and are optimised for car use. They are heavier, but use larger bearings and are sealed.
+1, once you use a Neu you won't want an el-cheapo motor again. After owning one the lowest I will go is a Medusa (and they're pretty good).
George16
Supermaxx
George16's Avatar
10.24.2008, 08:49 PM
Ditto. I just ordered a Medusa 36-70-2000Kv and Neu 1515 1Y for my next 2 projects. The medusa will go to my revo conversion and the 1515 will go to either a ST-RR or XT8. Haven't decided on which truck to get .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
