NeuMaxx
Tough MMM V1 need advice. -
10.26.2008, 03:19 PM
I have a MMM V1 that seems to work fine. It has with stood several 30 foot cartwheels when it either braoke the zip tie hold down or the servo tape and banged around inside. I have only run it on 4s but am planning 5s or 6s. Would you keep it or send it back?
10.26.2008, 03:43 PM
keep it...
10.26.2008, 03:46 PM
Keep it, but do the firmware update.
10.26.2008, 03:50 PM
i agree i would update the firmware and possibly request a v3 case but keep it for sure!
also a good thing to do
10.26.2008, 04:00 PM
worst case is that it eventually breaks then you can get the v3 right?
I don't understand, but I don't think I like it.
10.26.2008, 04:04 PM
I would keep it as well. I have a v1 that has been throughly abused and I regularly switch between 4s, 5s, and 6s. I have also read that people thought that changing their settings caused failures but I change my lvc everytime I run a different pack because I like a little more "cushion" than the auto setting has. It's also been in 3 different vehicles with no hiccups at all.
RC-Monster RC8T
10.26.2008, 04:05 PM
Keep it till about next April! Just before it goes out of warranty send it in for replacement. Who knows, by then they may be on v4-5, hopefully it will be v3 still though as I'm waiting to get my replacement and I hope it works well
10.26.2008, 04:46 PM
Get them to send you a case, and while you have ity open check the fan wires. If it still works i see no reason to swap it out. I have a v1 that is still doing fine, need to update the firmware before I run it again.
10.26.2008, 06:17 PM
I jus requested a new case for my V1. I'll be keeping my V1 and seeing how it goes with the new firmware
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
NeuMaxx
10.26.2008, 06:58 PM
I just upgraded the firmware so I will request a new case and I should be set at least untill next April. Thanks for all the advice guys.
Maybe Metairie, LA got the good ones.
10.26.2008, 07:22 PM
LOL, I don't think that's it because my 1st v1 failed. I bought this one from skellyo when I was waiting for Castle to replace it with a v2.
Supermaxx
10.26.2008, 07:35 PM
Send it to me Mark.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
10.26.2008, 07:45 PM
Why till April?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
NeuMaxx
10.26.2008, 08:59 PM
Warranty expires.
I think I will hold on to this one Lito. ;)
