e-mike
e-mike's Avatar
11.01.2008, 01:03 AM
Originally Posted by stum View Post
Yes I have the e-revo
22/58 on a 4s setup in the erevo is about 54mph on the top end.. considering the 4s 8000mah is the longest running config
16/58 is nice for racing ~40mph on 4s (rpms at about 40k)
ive try this set-up but my lipo come realy wwwwwottt(160f)and it was a pair of maxamps 7.4 8000mah,,,,lowest timing.....this is why i switch to 6 cell...geared 14/68,,,im borderline(rpm) but my lipo are cold(97f)motor 150f after 30 minutes and esc 112f
D8t on juice!!
stum
11.01.2008, 01:12 AM
The 8k packs don't typically get super hot until the last 1000mAH, if you are geared hot, I mean over 18/58 I wouldn't take the lipos to the LVC. I know what you mean about the temps though, I had one of my MA 8k packs poof a touch when running it hard to LVC also, but I was geared at 22 at the time. One pack was fine 130ish, the other was 150, mA replaced for free (warranty). I will say expecially with the 1.5d you need to be geared conservative to keep the amp draw down.. but high voltage is another good way to keep the amp draw lower as well :)
e-mike
e-mike's Avatar
11.01.2008, 01:24 AM
anyway if my temps still great i can run without problems......but my motor bearing have to survivelike your said stum going close to the cut off voltage do not help to cool down a lipo but i never reach the cut-off...20 minutes of runtime max on each pack....i prefer to have more pack..instead drawing all the mah of the lipo....but more expensive
D8t on juice!!
big greg
11.01.2008, 05:57 AM
specially considering the packs you are running.
those packs are the best tho, enerland cells! if he had the r's which i think so. i run mine next to my polyquest, exact same
johnrobholmes
johnrobholmes's Avatar
11.03.2008, 11:29 AM
MA carrying enerland cells? Not likely.
---JRH---
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
11.03.2008, 01:44 PM
i thought he was refering to the zippy's
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
bustitup
11.03.2008, 04:16 PM
ya I smell something...and its just not right
johnrobholmes
11.03.2008, 04:32 PM
Zippy R may not be china made, but I can guarantee it isn't enerland.
---JRH---
thisguy
11.03.2008, 11:14 PM
Couldn't really find an appropriate thread to ask so I chose what looked like the most active. So how long has it taken CC to send replacement v3's? I sent mine just over a week and a half ago. Just wondering when I can expect confirmation from CC for when they ship back the replacement v3.
e-mike
e-mike's Avatar
11.03.2008, 11:16 PM
dont worry castle always send a e-mail when they ship something
well me too im waithing for my fifth mmmv3
D8t on juice!!
Responce From Castle This Morning
bustitup
Responce From Castle This Morning - 11.06.2008, 12:44 PM
Nick,
We were reviewing your V3 MMM repair and had a few questions. The set-up
you are running appears to be a bit aggressive and may have contributed
to the failure. This should not have caused the controller to fail, but
it may be causing excessive stress on your battery or motor. We fear
your motor may have been demagnetized during this process, which may
have lead to the ESC failure. Again it should have not have failed, but
if the motor is demagnetized, abnormal problems may continue. I would
highly recommend sending the motor in to Steve Neu for inspection, just
to be on the safe side. If you wouldn't mind sending me a run down of
your set-up, we can make suggestions on how to prevent any future
problems. We will be replacing your failed V3 with a new version, but we
just want to make sure the set-up is proper to guarantee continuous
operation. Please let me know if you have any questions or concerns.
Thomas Porfert
Product Specialist
I wonder if this means a V4 is coming...is there anyway for me to test this motor for demag short of returning it to Nue?
castlemike
11.06.2008, 12:46 PM
That would just be a typo when he said new version. There is no V4............
bustitup
11.06.2008, 12:55 PM
I'm going to change my evil ways in the future and be much less agressive
so would a demagnitized motor cause a esc to go bad?
castlemike
11.06.2008, 01:16 PM
The obvious answer would be..........yes :)
bustitup
11.06.2008, 01:19 PM
ok just got off the phone with Odette at Neu...the motor is being shipped out tomorrow
