Batfish
Batfish's Avatar
11.11.2005, 11:08 PM
Here they are. Keep in mind that I have the RPM towers with no body posts mounted. The Jato body is resting on the top of the towers.
I think it looks very cool :)
As you can see, if you can mount the body that low you can even pull the sides out to cover the battery trays :)
Image hosted by Photobucket.com
Wanted to add, in case you didn't know, that is a Traxxas stock Jato body; it's just the clear one you can buy and paint yourself, so it's already cut out and the post holes drilled, etc...
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
