11.09.2008, 01:37 AM
Hey- good idea about using the 5mm bit to line it up! I actually have one of them somewhere..... It'll be a miracle if I can find it! I'll probably just use a stub axle or something... Of course I need to buy a 6mm drill bit but they aren't expensive.
Stub axle is a good idea, a drill bit can be difficult to line up as it is not solid. I eventually found 6mm bits on ebay, but you have more luck than I did locally...
