JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
11.12.2008, 06:44 PM
Originally Posted by Bronco View Post
Yes the switch is set to Master.
Using Stand Alone does this mean each cell will be discharged to the minimum voltage ?
Is a pack is out of balance, wouldn't I notice this when driving (punch, acceleration) ?
No, it won't discharge to the minimum voltage it just discharges the highest cells down to the vlotage of the lowest voltage. So if your cells are at say 3.8/4.1/4.1 your balancer will discharge the 2 cells that are at 4.1 down to 3.8 making them all equal.
You will not be able to feel if a pack is out of balance because the esc only sees the sum of all the cells.
