11.20.2008, 12:21 PM
Oh, . . . any plans for a 1512 version for 1/8 buggies then?
11.20.2008, 12:29 PM
Ummm, yeah. They are shipping now.
Patrick del Castillo
President, Principle Engineer
11.20.2008, 12:30 PM
Dang, sorry Patrick . . . I probably should have known that.
11.20.2008, 12:35 PM
Hey Patrick, I just checked your site and didn't see anything on them. Where can I find them to check pricing?
11.20.2008, 01:48 PM
So Patrick... Would the 9000kv motor handle 3s lipo? Maybe with the MMM and a very good 3s lipo. It would be for straight line speed runs, not constant use, and temps would be checked after each run.
Whoops -- lemme fix that statement I made earlier. They have shipped TO us, we have not yet stocked them.
You should be able to get them from Tower pretty soon.
11.20.2008, 01:53 PM
No, 2S Lipo max, 7 cell NiMh max. That's it.
The bearings will not survive --
11.20.2008, 02:20 PM
Hmm, what size bearings do those motors use? Do you think the rotor will hold up... If I kill it I will not send it back to you, experimenting is just that, experimenting!
Also are those motors still 2 pole designs? I just wonder as 9000kv at 3s lipo on a 4+ pole motor might be a bit much for a MMM or MM.
Thanks for the quick replys Patrick, always helpful!!
11.20.2008, 02:42 PM
sounds like a challenge! must kill one on 3s (at my own risk)! is my math off? They are rated over 100k rpm and 3s lipo should be 99900 rpm.
11.20.2008, 02:51 PM
I'll be waiting to see who's going to try 3S first lol. I can see it now, 300-400A spikes, oh man!!!! chase it!!!! it's smoking!!!! Bobby, how can I chase a ballistic missle  , just let it burn  ?
11.20.2008, 04:23 PM
Yep -- coming soon.
We are also working on a motor that will be sorta half-way between a 1515 and a CM36. So-- very fast 4s 10th buggies (read lotsa broken parts!) or more mild 1/8th buggies and 1/10th monster trucks.
Any idea on what kv size?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
11.20.2008, 06:05 PM
The bearing size is 14mm x 5mm x 5mm, which is REALLY big by 36mm motor standards. . . Helps with side loads and impacts (not than these motor ever actually take any impacts....  ) but is a little hard on the balls and race at really high RPM.
The bearings are rated for 75,000 RPM continuous, 100,000 short term.
Still a 2 pole design.
11.20.2008, 06:25 PM
I will have one of them in my 3S TFE dragster for at least a couple of passes. Not to worry Pdelcast and gang, I always send a check in with my repair orders
My TFE dragster:
11.20.2008, 06:42 PM
That's ungly. I'll take it out of your hands for free though. I'll make it look pretty lincpimp style.
11.20.2008, 06:43 PM
Wow those things move sunny!
