11.23.2008, 01:42 PM
I know that the 18v new style dewalt drill motor will not fit the erevo rear facing motor mount. The bolt pattern is wider than the 30mm bolt pattern setup. The dewalt motors are supposed to be the best, better than anything else out there in the same price range.
Best Bet.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Best Bet. - 11.23.2008, 06:27 PM
Your best bet in my opinion is to check out this site for what you want. He has the motors you need, and all kinds of adapter plate for mounting such setups. If you cannot find what you want send Dan and email and he can make up custom gear for your needs. I have the dual 18v 970 motors for one of my setups, but have not run it just yet. Too many projects going at one time. Good luck in your quest for more power and more speed.
http://www.kershawdesigns.com/
