speedy
11.28.2008, 04:51 AM
hm.. maby i'm crayzy but would it be possible to upgrade the driveline in an e-revo so it will handle an 1521 motor on 6s lipo? that would make my e-revo crazy fast and strong !!! Like 75mps topspeeds and backflipi'n wheelies !
Would a mmm handle an 1521 motor on 6s ?i'm going to use an ex fan and u-bec !!
Unsullied_Spy
Unsullied_Spy's Avatar
11.28.2008, 05:21 AM
Convert it to run 8mm axles (and center shafts), run RC-Monster hybrid diffs with Truggy diffs, and Tekno RC 17mm/8mm axle conversion should do it. 75 MPH top speed should be attainable with either 1/8th scale foams or HPI Phaltline tires and some serious gearing (Mod1/Revo gearing should suffice).
I would use a stock MMM, the external fan would definitely void the warranty and I'm not sure about the BEC. It should handle it just fine IMO, I'd ask Castle to be sure but I wouldn't worry.
azjc
12.06.2008, 09:52 AM
tires will be your problem, if you use solid foams you will have a much easier time going that fast
