Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.29.2008, 08:23 PM
A mamba 25 wont get you anywhere close to the speeds you're looking for. You'll need a nice motor like a neu or medusa with a 1/10th esc. A mamba 25 could get you to probably 35 in the detta. Maybe 45 if you can disable the bec. you'll probably want a 4s setup to get to 62mph.
Byte
11.30.2008, 06:38 AM
So first I will try what the speed will be with a Mamba-25 and the 8000kv motor (And I guess I won't get 62mph with stock gearing)
The next step will be a MMM and the 8000kv motor.. (Just to see the difference between the mamba-25 and MMM)
And the last step will be purchasing a NEU, and finally get 62mph
@Metallover: This vendetta is yours I think? http://www.youtube.com/watch?v=S32YX...eature=related
Could you say me what motor is in it? On youtube it says: "Neu 1107/1.5D" but that motor doesn't exist?
EDIT: The only problem is a 3S LiPo.. I can't find a good one, that will fit.. :(
Thanks!
Byte
11.30.2008, 08:31 AM
I saw this 3 cell LiPo: http://www.lrp.cc/de/produkte/vtec-a...-111v/details/
Do you guys think this is a good one for speedruns?
Metallover
Metallover's Avatar
11.30.2008, 02:32 PM
Thanks!
The motor is an 1107/1.5d that is 8500kv. I purchased it from a guy on here slightly used. I'm guessing Neu stopped making that motor or he got a special wind. If you are running 3-4s you can't use that motor.
If you are doing speed runs you have to improvise on battery fitting. A lot of people have custom chassis to fit everything. I think you can put one in the battery tray and one perpendicular to the first one above everything else. The mmm will make it more of a challenge...
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.30.2008, 04:19 PM
Neu used to mass produce the 1107/1.5d. I got it from diversity models back when they were still in business, then sold it to metallover.
Byte, here's a good 3s lipo that will fit your vendetta with no mods. I've been using this with great results.
http://www.2dogrc.com/ecommerce/os/c...nt-p-2178.html
They are expensive compared to others, but are a perfect fit, and dish out loads of power.
rcm xt8
rcm xb8
rcm crt.5
