SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.02.2008, 07:14 PM
A while back I actually emailed novak about this question except using an external bec instead, and they still said not to do it as it would damage the components inside the esc. But maybe they didn't understand the part about using the external bec. Either way if you do try to put 3s on the gtb, you must use an external bec. The linear bec of the gtb can't handle much more voltage of 6 nimh cells. That's why its not even rated for 7 cells ni-mh.
Area 52 Ranch Raceway
T.R.C.R.
