rchippie
rchippie's Avatar
12.06.2008, 09:38 PM
Originally Posted by tha5150 View Post
new to the buggies. i had an emaxx i started out with for a year now and getting sick of it. i have a friend locally that just got one and now i am hooked. plus i just found a race track right down the street. looking at a few different ones to convert to brushless. Ofna 8 Hyper, Ofna Hyper 8 Pro 8.5, 8.5 pro, Losi Eight and another 8 Hyper Main.
not sure the differences in all of these are but i would assume the higher number means the newer the model.
anyone have any advice on either of these?
i understand all i will need to convert is a motor mount from Mike and a battery tray from Losi or Mike. is this correct?
what kinda speed/torque can i expect with a MMM and Fiego 8XL????
Out of all the buggys you have listed, in my opinion the losi 8B is the best . I ran my jammin buggy on 4s & a 9xl it was more than enough speed & power . The 8XL will be slightly faster . But it may have heat issues & a little less runtime depending on your gearing.
This is a rough idea of what you can expect using a 8XL on 4s. If your going to use a feigo the 9XL would be a better choice . I got a solid 15 min on mine before the lvc tripped .
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 47
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 4.1
Tire Ballooning (inches): 0
Motor Current Draw: 30
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.36 : 1
Total Ratio: 11.1044 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 30386.8 RPM
Vehicle Speed: 33.38 mph (53.62 km/h)
Estimated Adjusted Speed: 32 mph (51 km/h) - 4% loss
Effective KV Value: 2053.16
KT constant: 0.65 oz-in/A
Motor Torque:
REAL MEN RUN BRUSHLESS
