Superemaxx89
03.01.2005, 10:05 PM
you make a good point! I actually don't find the 4mm that hard to install, all i do is soak the wire in solder, then heat up the connector, and since gold is extremley conductive, the heat is tranferred efficiently enough to where all you do is put the soldering iron on the connector, then push the solder soaked wire right in the connector. You probably already know that though:)
Do the deans wear out ever? (i know everything wears out eventually, so don't pull one of those on me :cool: ). I ask this because i know there are indeed spring type things in the connectors, and i'm wondering if the wear out due to excessive heat.
Oh ya, by the way, with you being the guru of this forum, have you ever posted pictures of your truck anywhere?
