I used a axial battery mount from my ax-10. It has holes in it that you can use to mount it to the chassis. The back hole fits in the motor screw slot. The front hole has to be drilled. Then the battery stays in place using the velcro straps. I can snap a pic of it tonight when I get home from work.
