Will the hotbodies hardened diff internam gears fit the CRT DiFF
cheesecake
12.13.2008, 09:49 PM
you will be fine with the standard crt diff gears i reccomend replacing the diff cup also when you replace the gears incase the case has gotten warped from use
cheesecake
