12.23.2008, 10:15 PM
A 14xl is way too low kv to run on 4s, 8s is more like what that motor needs. You do not need anything more the cc motor, maybe the traxxas vxl motor if you plan to run 4s.
Personally I would go with the 4600/mm setup on 3s lipo. Simple, easy to use, should have good temps, and will not require any mods to the esc to run correctly. You could also go with the velineon system from taxxas, but it does not offer the pc compatability. A cheaper esc would be the sidewinder, but used MM systems go for cheap...
