12.30.2008, 04:18 AM
Originally Posted by Unsullied_Spy View Post
+1
That metal spur gear will actually make more noise. It won't strip and as long as both it and your pinion are properly hardened it shouldn't wear out but it'll be louder than a delrin spur gear. I'm thinking that noise is mostly just the motor.
It is a 4 pole motor, and will make a notchy noise when the motor decelerates (sp?)... I run a metal spur and pinion on my lst, and with just the right mesh it is actually almost as quite as the plastic spur on the erevo... If the mesh is off it makes noise, quite a bit too....
