Waterjet cutting carbon fiber
pb4ugo
Waterjet cutting carbon fiber - 12.31.2008, 02:21 PM
Thought I'd share my experience here. I'd always heard it was the preferred method, but also heard an occasional argument saying it would fray the edges.
I took a small scrap piece to my local shop and had them cut a trial circle out. The shop was doing me a favor and putting me on between jobs of cutting 1/4" (6.35mm) steel, so they did not change the setup at all for my 2.5mm material. The results would be better if they had.
The only downside I could find with it is a slight clouding in the finish around the edges. This was caused by overspray of the abrasive. It would be lessened had they setup for my thickness. Otherwise a layer of plastic wrap or even masking tape on the material first would prevent it.
Here are the pics. Only the two circles were a result of the waterjet. The rough edge cuts are mine from a Dremel.
pb4ugo
12.31.2008, 02:45 PM
As an afterthought here, I'm sure the layup of the carbon has alot to do with your results. If you had a somewhat dry section, I could see a waterjet cut causing it to fray for sure. This piece was fully consolidated with epoxy.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.31.2008, 02:56 PM
IMHO, waterjet pwns all.
12.31.2008, 08:49 PM
damn it. I really hoped the silent p wouldn't invade this forum. I don't understand it at all and things outside my comfort zone scare me. pI pguess pif pI pcan't pbeat pthem pI pmay pas pwell pjoin pthem.
What's_nitro?
12.31.2008, 10:08 PM
Except that it's meant as an intentional typo, not just an extra letter! (...was he joking?)
12.31.2008, 10:13 PM
i know. why can't people just say "own" or "owned" It really makes me pmad
What's_nitro?
12.31.2008, 10:17 PM
Hahaha, it's because saying "pwned" makes you sound like such a 1337 h4xx0r. N00b.
12.31.2008, 10:25 PM
"i sometimes make up words too" -homer simpson
dkexige
01.02.2009, 06:43 AM
Are those little notches for the cut-in characteristic for waterjet cuts? Just curious, I have no experience whatsoever with it. I've only seen it on American Chopper
.dk
pb4ugo
01.02.2009, 01:06 PM
If you're talking about the start in the center of the circle to work out to it, no it is not necessary. It is a more cautious way to do it since we were testing. If you are talking the little nipple left at the start/beginning of the circle, then it is not normal, just the result of o poor program and setup.
