E-fanatic
Brushless only!
E-fanatic's Avatar
01.03.2009, 11:02 PM
With a powerful brushless a slipper doesnt solve the problem. I tried a few cvds and broke them running on 4s with a loose slipper. The only ones that has held up to locked slipper 6s lipo abuse is the mip 1665 cvds(was trying to see if the cvds would hold up, I broke 4 diffs, 2 sets of center shafts, and the tranny trying to see if the mips would hold and they did). They are expensive but worth every penny. I dont care or the cvd pin but when you put the cvds together dremal a flat spot in the pin and locktite the set screw down in the flat spot and they will not come apart.
