01.07.2009, 10:02 PM
Can't beat castle for a good price, that is for sure. If I was going to suggest a cheap bl system for using nimhs on it would be a Mamba Monster esc and a 9xl feigao. Should cost slightly over 200 bucks and will run well with nimhs if geated correctly. Only issue is that you would have to buy pinion gears that have a 5mm bore. If you geared that setup for 35mph the nimhs will survive. Plus you will have the best esc around, and the future potential to upgrade to lipo as that speed control has a low voltage cutoff, which is mandatory for lipo. Still cheaper than the novak 6.5 system, even with a few pinions.
