01.09.2009, 08:48 PM
Originally Posted by SidewaysLS4 View Post
Yeah, I wonder if - current is read also. I wonder if the regen current gets past the esc to the battery?
The ET device most probably reads the voltage drop across a very small (like 0.001 ohm) precision resistor shunt. If current is going the other way into the battery, the voltage read would be negative. Not sure if it can read that.
Originally Posted by Mozzy View Post
...Can this be confirmed by an actual ESC designer & not by someone that assumes?
Patrick (Pdelcast) from CC has indeed stated they are regenerative.
