MetalMan
MetalMan's Avatar
11.26.2005, 08:41 PM
Originally posted by SpEEdyBL
I would go with a 380 motor if I were you and gear extremely low. 500 watts would give you well over 150 pounds of torque at the wheels and have a max speed of 3 mph. The 540 motors would just heat up since there wouldn't be much of a load on them.
This is some good advice. The reason being that if a BL motor is undergeared, it will run inefficiently, and will heat up. So, if you have a larger motor, it will require more of a load.
The HV-Maxx on a low cell count (6 cells?) could work very well. Being sensored, you don't have to worry about cogging.
