Gee
A Horse's Ass
Gee's Avatar
01.14.2009, 10:51 PM
Depends on how anal you are. No offense to you or any other one that thinks they are anal. Just joking around. But if your are just out bashing you can just make a deans lead/extension that has the UBEC soldered to it. Then just plug it in line when you are using it. If that makes any sense. I used them that way when I was sharing UBEC between a couple RC a while back. Worked fine for messing around. Also use a servo extension and remove the red wire from it and leave all the wires intact on you esc. You probably already knew that.
http://www.rc-monster.com/proddetail...stlebec&cat=21
CCBEC is a good one
