01.18.2009, 05:20 PM
Nitro killing is easy with BL, no worries there.
What are the diff ratios (front/rear) or the ring and pinion tooth counts, and the tire diameter.
When you know that much, you can then use the gearing calc to fine tune your gearing for your desired speed- 40-45mph should be plenty..
