E-Traxxer
11.27.2005, 09:28 PM
Originally posted by MetalMan
By "tear the truck apart" I mean that this system could very well be capable of doing just that. Pulling full throttle from a dead stop would make it do more than just wheelie!
But I have a wheelie bar! :p I don't think it could tear any drivetrain component up after my fully redone drivetrain is done, there wont be a single peice of plastic in the drivetrain besides the HB cups, which are stronger and better than aluminum cups.
Mack- The specs ARE good, but it is only a plane controller. It has a possibility to handle a lower amp draw motor (such as the 14XL I'm going to use in my possible setup) on a higher voltage setup because the motor won't be pulling as many amps, so he controller will be able to cope with the smaller amp spikes.
