jayjay283
jayjay283's Avatar
01.19.2009, 12:00 AM
Originally Posted by asheck View Post
I want to know what tires you run.I have yet to find a good 50+ mph bashing tire.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.8333333333333334
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 26
Total Voltage: 18.5
Motor KV: 2050
Tire Diameter (inches): 5.60
Tire Ballooning (inches): .5
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.08 : 1
Total Ratio: 12.59467 : 1
Tire Circumference (inches): 20.73 inches (526.66 mm)
Total Motor Speed: 37925 RPM
Vehicle Speed: 59.12 mph (94.97 km/h)
Effective KV Value: 2050
KT constant: 0.66 oz-in/A
Tires and wheels are post #29 http://www.rc-monster.com/forum/show...t=13590&page=2 only combo that holds up, even the phaltlines farted on me at about 52 mph
George, Got the neice a videocam for xmas, soon as I can pry it out of her paws ill video it....heres it on 5s on a 9xl before I put in a higher KV motor and regeared it with the UEs http://www.youtube.com/watch?v=suq5i8IqEUk
George16
Supermaxx
George16's Avatar
01.19.2009, 12:14 AM
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 2050
Motor coil Ω: 0
Jay, I had seen your truck run before. I was just busting your chops .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
